Sherline Mill 5400 or 5800 and Packages
Mike, I will be getting the 4400 lathe as well. I didn't really have any question in my head about this one so that's why I was mostly asking about the mill.
Since you bring it up though; any things I should consider for the lathe? I'm really starting to consider not getting a "package" but just buying the lathe and mill and a few accessories that I think are worth it from Sherline but sourcing some better stuff like you said (e,g the drill chuck).
Do you know if there is anything that I should definitely add to my order from Sherline that would be hard to source? For example, I would like to get a 4 jaw independent chuck for the lathe... should I just get this from Sherline or can I do better? My concern is finding tooling that fits the lathe (maybe that's not that hard and I'm just over thinking it).
Also, any opinion on inserted tooling on for the lathe? I have been hearing that, while it can work, it is not superior and you can't really take advantage of it on such a small machine but I have seen many people using it without complaint and getting great results. My attraction to inserted tooling is not having to grind my own tools (which is another space, mess, machine concern for my little work area). I'm not so worried about the cost factor but the usability factor; which would add the most value. Any thoughts?
Thanks a lot for your help with this. I really appreciate it!
That book by Joe Martin that Mikey mentioned is worth getting. Maybe ask Sherline if they have a copy to sell you. Good machining advise for beginners. For example don’t buy a set of taps because the quality is low, buy what you need as you go. And the interesting story of how he got involved in Sherline and grew the business.
Wow, I just looked at the 5800 mill. I can’t believe it’s over $2K! Has somebody lost the value of a dollar? I would make my dollar go a lot farther with better quality machinery.
Glad you're considering the 4400, Adam. I'll be honest and say that when my work piece drops below 1" OD, I prefer to work on the Sherline lathe. My lathe is outfitted with a VS DC Leeson motor hooked up to the leadscrew when I need it. This allows me to vary both speed and feed to precisely dial in a cut; it is, without a doubt, the ideal set up for a Sherline lathe.
Okay, here is what I would buy:
  • 3", 3JC - buy the Sherline version. Very high quality, very accurate.
  • 3", 4JC - ditto.
  • Steady rest (very important)
  • Follow rest (not as important but necessary for some long work).
  • Live center. Make a better one later.
  • MT0 drill chuck adaptor that allow you to use a 3/8" keyless chuck. Albrechts are the best but a cheaper Rohm Supra is fine. I own two Rohm chucks and two Albrechts for my Sherline and all work about the same. I also have the Sherline keyed chuck; its good but the keyless is better.
  • Beall ER32 chuck - fits both lathe and mill. There will come a time when you use gravers and this chuck will save your knuckles, believe me. Pretty accurate, too.
  • Buy an OXA quick change tool post. Sherline's rocker tool post is okay but slow to use. Too bad A2Z went out of business; they made a good one. Might find a used on on ebay. Otherwise, import is the only realistic choice. Aloris makes a mini-tool post that fits the Sherline lathe but the cost will make you weep.
  • Threading attachment - this is a critical piece of equipment that will allow you to cut almost any thread you can possibly use. It can cut class 3 threads, both internal and external, and I would not do without this accessory.
  • A good dial indicator to dial work in on the 4JC. You can make a indicator holder to screw onto your cross slide or tool post.
  • Make, do not buy, a rear mounted parting tool post. Use a P1-N blade with a 7 degree relief angle up front. The Sherline lathe does not like to part from the front and I wouldn't waste money buying the tool holder to do it. For this one, make your own: http://www.machinistblog.com/?s=parting+tool&submit=Search
That's all I can think of as vital but I may come edit this later.
Insofar as turning tools go, most beginners go with inserts. If you want to try carbide, buy a 3/8" set from PM: http://www.precisionmatthews.com/shop/38-turning-38-boring-tool-set/. This is an outstanding deal on a set like this. They are SCLCR and SCLCL tools and CCMT and CCGT inserts with a boring bar thrown in. The
Sherline can almost go fast enough to actually make you like these tools.
If you want to go with re-sharpenable HSS inserts then AR Warner is the way to go: http://www.arwarnerco.com/p-12-kit-8-38-inch-turning-c-right-hand-left-hand-and-boring-bar.aspx; I own these tools and can tell you that they are fine tools and work well. The inserts cost a lot but they can be sharpened by honing the tops. No chip breakers so they cut with lower cutting forces.
Ideally, you want to use shop-ground 3/8" HSS tooling on this lathe. A good general purpose turning tool will easily outperform either of the inserted tools linked to above. We recently had a very good discussion on this topic here: https://www.hobby-machinist.com/threads/models-for-grinding-hss-lathe-tools.62111/. I encourage you to learn to grind tools. It is a skill so it can be learned, and the benefits far outweigh the hassle or expense to get started. I own inserted carbide AND inserted HSS tools and they sit in a drawer. Give it some thought.
This will get you started, Adam. There are tools that you can make to expand on the capabilities of this lathe. Check the Sherline section of the forum for ideas. If you get stuck, post or you can PM me, too.
I asked essentially the same questions when I bought my lathe (4400) and again when I bought my mill (5400 with extended column). I'm on the small side of what the Sherlines can do so a larger machine wasn't even a consideration for me, just Sherline, Taig or Chinese mini lathe / mill. I've been very happy with my choice, it is very clear Sherline puts a lot of care into the assembly of their tools.
What my experience was after looking at buying things individually or as a package, the Lathe packages are pretty solid, I went with the C package which is quite extensive and a great deal, I think I figured out you get the tooling for like 50% of the individual price. I've added a few more things I may use but I got everything I needed with the C package.
The mill package I found it made more sense to buy the mill alone, too many things were included that I either didn't need right away, duplicated items I got in the lathe package, or was advised I would want to replace with something other than what Sherline offers.
I bought the lathe and mill individually a year apart, so I'm not really familiar with the specific combination lathe / mill deals. I also went with the baseline, no DRO or CNC ready.
One of the other things is keep an eye on Ebay, I have a constant watch and email for stuff posed for Sherline. Got the rotary table for 1/3 of the price and do not think the person ever used it. I have got other tools as well. Like mikey I often revert to the sherline for small items.
Well, I think I am just going to get the CNC package with the ball screw upgrade. I will be adding the other tooling you guys have suggested as I go. I was doing some pricing and it really isn't any cheaper to just mix and match what you want vs just getting the package and adding a few items.
So my plan is this:
From Sherline:
  • 6010 CNC Package (5410 mill and 4410 lathe, yes I'm a metric guy) going to try and get this with the 15" column and 18" table
  • 4" 4 jaw independent chuck
  • 3560 Mill Tooling Plate (4″ X 10″)
  • QCTP? (not sure about this, it's expensive but the only OXA ones I can find cheap Chinese ones... they might be fine though...)
  • 1202 Tailstock Chuck Holders (so I can use a keyless chuck)
After market items:
  • Beall ER32 chuck and collets
  • Better 2" Screwless vise
  • Rohm 871049 keyless chuck (3/8" mount, 1/2" capacity)
These are the "bootstrap" items I plan on getting. Things like a better boring head will come later. I am also going to pass on inserted tooling until I've had some experience to actually make a decision about its usefulness for myself since I hear mostly that ground HSS won't steer me wrong to start with.
Anyone see anything out of whack?
Just a suggestion but I would spring for a wedge-type QCTP from LMS instead of the Sherline one, reason being the cost of additional tool holders. Sherline tool holders are $68.00 each, while LMS 000 holders or other 000 holders will be a bit over $10.00 each and they will all work the same. Sherlines post is nice but not nice enough to warrant the cost.
For a drill chuck, I suggest a 3/8" chuck instead of 1/2". The tailstock taper won't handle huge drills anyway.
You MUST have the threading attachment, please take my word for this.
Overall, I think the package is okay otherwise. I would include a column riser, though. This will raise the milling column up so that a 2" vise will pass under the bottom of the column and give you more room in Y.
I'll add the threading attachment. I was kind of hoping to get into using a stepper to drive the spindle and do threading with CNC but that might be jumping the gun and I will probably be better off (or having more success with) doing things manually to start with. I'm in this limbo ground on CNC; I love the automation aspects of it (I'm a software developer by day so this hits me in the feels) but I am also really interested in manual techniques as well. I kind of planned on using the CNC in MDI for some pseudo power feed at first. Either way, I will take your advice to heart.
Do you mean a 3/8 maximum capacity chuck? I went 1/2" because that was the largest they had for 3/8 mount. If this is too big I'll scale back to 3/8 capacity.
Wasn't sure about the riser since I was going to shoot for the extended column but you bring up a good point. Any thoughts on the extended headstock spacer? The package comes with a 1-1/4" spacer but they also have a 2-1/2" spacer available wondering if this is worthwhile or if you've used it before.
It amazes me what CNC machines and their operators can do with them. However, I agree with your thoughts about learning to manually machine first. This will teach you about how metal likes to be cut. There is a sound, a feel, a touch to working metal manually that you will not get by starting with CNC. If something goes wrong, you will know it but more importantly, you will know how to fix it. It sounds like you're the ideal guy to go CNC, though.
Yes, I mean a 3/8" capacity chuck. Remember that on the lathe, you only have a MT0 taper that is not locked into the tailstock taper by a drawbar. You can use 1/2" drills but you'll have to step drill up to it most of the time because the taper won't hold that large a drill, even if the chuck will. I usually drill up to 3/8" and if I have to go larger then I either carefully step drill it or bore it. I have reduced shank drills up to 1/2".
I have the extended column on a column riser to max out room in Y. I also have the 1-1/4" headstock riser to give me more room in Y. The former mods allow my vises to get under the column and the latter gets me over the vise with the table in near mid-position. I think all three mods are important to have on a 5400 mill.
I also have the rotary column thing that lets you tilt the entire column side to side. I thought I would need it someday but I've never used it. Like the adjustable ram thing on the 2000 mill, potential for movement of a mill head or column is not a good thing. The more rigid and solid you can get things, the better.
You are going to love your machines, Adam. Everything these machines teach you transfers to larger machines so if you step up to a larger lathe or mill someday, you will be ready.
