Wow, Stone, you have gotten a lot done!
Mine is in the basement now, awaiting the reassembly and restoration.
There are some photos of it on here. I am building a hoist on the basement joists to lift it up.
I have copied a lot of your threads from the other site to use as helpful reference.
I know I'm a PITA, and have picked Cal's brain on this machine in private email, but
I would like to hear how some of these jobs are done since I am GREEN and will no
doubt need to do the same on my 1946 mill:
Replace main and gearbox motor bearing - my feed gearbox is off the mill, now would be the time to check it
Rebore main pulley for taper lock fitting- did you make one on your lathe or buy one?
change all oil- pretty self explanatory
replace the table leadscrew and nut, all the table bearings, and the knee screw and bearing-
this is a ton of work. Did you make a new leadscrew or get one? Which bearings does it take?
Scrape the knee /saddle ways. major wear here.
Scrape a little on the table.
Very hard and specialized work- how did you learn to do this?
Adjust the spindle bearing lash- This would help to know too.
Replace the sight glass- mine works amazingly, BUT I would love to have a separate brass/glass oiler- easier to see.
Drive chain- Mine is shot on the table feed to motor.
Maybe start a new thread if you could?
Thanks,
Nelson
