Show us your Van Norman #12 Milling Machine!
HMF
Site Founder
Administrator
Show us your Van Norman #12 milling machine, either before or after or both!
Thanks!
Nelson
!BmN6+V!B2k~$(KGrHqUOKiUEtmHv5NInBLe19pZviQ~~_12.jpg m-12.jpg n_aCAUQQKAQ.jpg n_aCAXWJEAX.jpg VN_12_Vert.jpg n_aCAMH74G3.jpg n_aCA5ME75Z.jpg 21-587-005.jpg VN_12_Horiz.jpg n_aCACN8FBI.jpg VN_12.jpg n_aCA3FC7RR.jpg n_aCAD5PCNG.jpg
Hmmm- good thing I cleaned it- if I showed a pic of it in as found condition it would be tough on the gag reflex. Imagine five coats of paint, all chipped, a never removed layer of slush oil hardened on, 70 years of grease, many layers of chips, and nice solid coat of sawdust and mouse ****, a sump full of gunge and a mummified rat. At least the rust is minimal!
No, not up and running- I cleaned and relubed the head, adjusted the spindle bearings, and scraped the spindle taper id to get rid of the residue from spun collets- it is running pretty true now- .00015 or so.Good enough for me for now. It is apart now and I am working on the ways.
Wow, Stone, you have gotten a lot done!
Mine is in the basement now, awaiting the reassembly and restoration.
There are some photos of it on here. I am building a hoist on the basement joists to lift it up.
I have copied a lot of your threads from the other site to use as helpful reference.
I know I'm a PITA, and have picked Cal's brain on this machine in private email, but
I would like to hear how some of these jobs are done since I am GREEN and will no
doubt need to do the same on my 1946 mill:
Replace main and gearbox motor bearing - my feed gearbox is off the mill, now would be the time to check it
Rebore main pulley for taper lock fitting- did you make one on your lathe or buy one?
change all oil- pretty self explanatory
replace the table leadscrew and nut, all the table bearings, and the knee screw and bearing-
this is a ton of work. Did you make a new leadscrew or get one? Which bearings does it take?
Scrape the knee /saddle ways. major wear here.
Scrape a little on the table.
Very hard and specialized work- how did you learn to do this?
Adjust the spindle bearing lash- This would help to know too.
Replace the sight glass- mine works amazingly, BUT I would love to have a separate brass/glass oiler- easier to see.
Drive chain- Mine is shot on the table feed to motor.
Maybe start a new thread if you could?
Thanks,
Nelson
I'm still new to machining, and expect I will have to bother Cal quite a bit, if I can.
I got the machine down to the basement, thanks to help from Cal in rigging it.
The service line and disconnect went in yesterday.
I have to hoist the machine back together- will build a hoist on the overhead joists.
Then the cleaning, restoration, wiring and other fun begin (hopefully).
:tiphat:Nelson
