- Sep 28, 2013
- 4,333
I'm sure this has been covered before, but I figured I'd share what I learned. Lots of YT vids on this, most covering almost all of what I found out.
Anyway, first you need a jig to hold the ends of the band together and straight. I made mine out of some stainless angle, scrap and 1/4-28 wing nuts I had lying around
Grind both ends of the break square, then chamfer each end so the scarf is around 1/4" long. Coat both ends in liberal amounts of brazing flux (I used Harris Black high temp flux).
Align the ends in the jig and clamp down. You should have a very small void at either end of the overlap.
Heat the joint with a propane torch until the flux melts and the band turns red all around the joint. Carefully feed in some silver solder (45-55% silver, I used 50%) and play it along the joint. It should wick into the joint. If it doesn't melt, you don't have the joint hot enough. Only add enough to fill that void.
Grind off the flux and excess silver solder with a dremel or equivalent. It'll look something like this:
that was my first failed attempt, shouldn't look like that![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Let it cool then sand about 1" either side of the joint until the metal is bright and clean. Put your torch on a lower setting and play it over the bright area until it starts to turn straw/ brown colour. You need to do this annealing step or the band might not be flexible enough and cause the joint to fail.
So after the 3rd or 4th attempt, I got the band to stay together!
and after the 4th or 5th attempt I got it to stay together while cutting metal! Woohoo! The joint looked a bit ugly, but it held
and then I could finally finish cutting through the piece of stock on the bandsaw
pretty darned pleased with myself!
