- May 31, 2018
- 184
Saml, I have that same lathe, though mine is badged Kent KLS-1340A. On the front it says KENT USA. On the back, on a small and partially hidden tag it says "Made in China." Gray instead of green. Still, pretty nice lathe for what I use it for. Yours does look like it might be narrower (shorter bed) so maybe it is a 13x30 (?) Mine measures 55" from the right side of the headstock to the end of the ways.
I was under the impression when I bought it that it was a Taiwanese machine but, as far as I can see, there is no country if manufacture on the machine anywhere so it could well be. It’s 1 meter between centres so just shy of 40” although you can’t get a 1 meter part in there! Here is is maxed out!
![741D27B4-5B75-4C28-AC95-7D9FEE6B001A.jpeg 741D27B4-5B75-4C28-AC95-7D9FEE6B001A.jpeg](https://www.hobby-machinist.com/data/attachments/262/262074-b49f7e26c38c8c6802c1f558f35d155b.jpg)
A couple mm extra and I would have been in trouble!
Neither chuck is an adjust true type but the real reason was for clamping purposes anyway. I couldn’t grip on the OD as there was a small lip and the big chuck was too large to grip the ID. This method was quick and dirty but I was only facing a few mm off so it was plenty good enough.Whats the purpose for clamping your part into a small 3 jaw chuck that is then clamped into a larger 3 jaw chuck? Looking at the picture the part looks like it would have fit into the larger 3 jaw without needing the smaller chuck and neither of those 2 chucks appear to be adjustable like a Buck Adjust-Tru type of chuck to help with the run out which adds to the confusion.
