Spider would not require internal bearings, and the bore size of the bearings shows that it is a ball bearing center. The picture also shows that it is mounted into a tapered sleeve by the looks of things. The faceplate may be some misdirection!
The bearing sits inside the spyder and allows the barrel to rotate freely with total support. Much smother than just snugging up the barrel on brass pads. I still want that car and trip for the correct answer.
