- Mar 5, 2012
- 314
The base looks great
welding cast iron can be very tricky
Get a VFD and get it operational…I got one of those Swede gear driven drill presses. Bought it at an auction years ago and used in my town shop. But since it’s three phase and I don’t have three phase at home, it just sits in the corner!
Bones
Ok, I went to Amazon and saw the VFDs they range in price from around $84 to over $250. Will the cheap one work as good as the high dollar one? I do not need variable speed as this drill has a huge number of combo of gears for speeds as low as 100 to 2500 rpm , if I remember correctly! Any help appreciated!Get a VFD and get it operational…
Someone with more knowledge will chime in… but key is to get the one to supports the HP of the motor…Ok, I went to Amazon and saw the VFDs they range in price from around $84 to over $250. Will the cheap one work as good as the high dollar one? I do not need variable speed as this drill has a huge number of combo of gears for speeds as low as 100 to 2500 rpm , if I remember correctly! Any help appreciated!
Bones
Thanks! I think that is what is on my Clausing lathe. I do have several big 3 phase motors.I was at one time planning on building a rotary converter, but like many of my projects, it got put on the back burner. I have a three horsepower single phase motor for my 17 inch LeBlond lathe.If you have switches built in that you would like to utilize it will require additional work besides just hooking the AC input to a VFD. If you just need to supply 3 phase to your machine I can definitely recommend these guys.
SPC-3
Run motors at two-thirds power with the heavy duty SPC-3 Static Phase Converter. This static phase converter offers reliable performance for any industry.www.northamericaphaseconverters.com
You will loose approximately 1/3 power but in practice that's rarely an issue. It'll keep you from having to do any internal wiring changes and if you decide to build a rotary phase converter down the line all you'll need is a 3 phase motor.
John
Nice base! OSHA made us either bolt the drill press to the concrete or bolt it to a large steel plate that sticks out so you can trip over it.
