Hi Guys
I am having trouble learning about spur gears for a project.
I require a gear set of 112 teeth and 14 teeth and I can redesign my entire project around the gear set- In metric modules they are expensive at $1000 AUD (including 8 of the smaller gear) but I have noticed that 64 DP 112 Tooth gears start at $10 each but I cannot find a 64DP 14 Teeth gear, surely it is possible because it can be done in metric, is there something I am missing? Will a smaller DP still mesh with the 64DP 112 Tooth gear? Or does anyone know where I can buy 64DP 14 Teeth gears?
Cheers for your time.
