- Apr 14, 2014
- 3,215
I've had a Startrite model H175W horizontal/vertical bandsaw going on 20 years. The saw was used when I purchased it with a build date of 1985. As luck would have it I no more than finished up restoring the Baileigh cold saw and the gearbox on the Startrite started leaking. It wasn't much of a leak, but enough to put a few drops of oil on the shop floor. I decided last week to disassemble a few things to see if the leak could easily be corrected. It turned out the only problem was a failed grease seal behind the band drive wheel. I was able to replace the seal and pump in a little more grease without any problems.
While I was working on it, I decided to see why the coolant pump was inoperative. In all the time I've had the machine I've never used the coolant system. The saw has always done a good job and I haven't had the mess and smell that goes along with coolant. After seeing how well the coolant system worked on the cold saw, I thought I'd see if I could resurrect the one on this saw. The problem turned out to be minor in that the only thing wrong was dried coolant preventing the impeller from turning. When the impeller wouldn't turn it kept tripping the circuit breaker.
Unfortunately, I had to disassemble the motor to remove it from the machine. What I didn't realize was that the motor was filled with oil. When I removed the end cap all the oil ran on the floor. Some research reveals it was filled with mineral oil. I'm not sure if there's any viscosity or dielectric property differences between brands of mineral oil. I would appreciate any input from you electrical geniuses on the subject. If in fact all mineral oils are pretty much the same, I can go down to the local Home Depot and buy a quart. On the other hand, if I need something special, I would appreciate knowing it before I do something stupid.
