- Oct 4, 2011
- 727
You must have filed some relief on the tap or it would not have cut.
I make quick taps by some old time tricks. They work perfectly well. When I make parts for antique mechanisms they always need special threads.
A suitable tap can be made by just filing them square or triangular. In the 18th. C.,taps were made that way commercially. They cut very well. I have made taps by filing a tapered flat spot on 1 side of the tap. The flat at the nose is 1/2 the diameter of the tap,tapering out quickly to nothing in about 3/8". The important thing is to then file the threads into a relief so that the foremost cutting edge is higher than the area behind it,or it won't cut. As long as the threads themselves are correct,these quick taps leave a threaded hole just as good as any other tap will. They are not for high production,just for a few special threads. I harden them,and draw to a dark brown color. Some temper to purple,which is just below blue. Blue is 52 Rockwell,and getting too soft to hold up on steel.
George could you post a picture of how you file yours? I'm not sure I did it right with mine and it only worked because it is in brass.
Jeff
