- Sep 28, 2013
- 4,318
I needed a 2nd chuck key for my 4 jaw so I figured I'd use my new collet chuck (http://www.hobby-machinist.com/threads/er25-collet-chuck-for-atlas-618.41636/) to make one I got my inspiration from a tap handle I was fiddling with - this way I can move the handle around for clearance or leverage.
stock - random printer bars I think
back end of the key faced and beveled
drilled about an inch deep with a #30 drill, as I was going to use 1/8 brass stock for the button
1/8 brass stock in a 3mm collet - it was then turned down to fit inside the spring and parted off
turned round, put in a 2mm collet (love this chuck!) and faced
ta da!
end of the chuck key body turned down to what I thought was the right size, turned out a bit small so the edges won't be bevelled
ta da!
