- May 3, 2017
- 1,999
DittoIf you really want to be spiffy, I would go with the "Machinist Calc Pro 2" calculator. It is specifically designed for working out machining related problems.
Someone could/should write a tutorial on the basic use of Trig for this site.
I DO! I DO WANT TO BE SPIFFY!!! I'M ON IT!Ditto
That TI-30SLR is a real classic. Bet it still works, too...Someone could/should write a tutorial on the basic use of Trig for this site.
Robert
Don't overthink it. Most of the requirements are pretty basic. A $10 scientific calculator from Walmart will do all of your calculations for you. If you don't want to spend the $10, your computer or smart phone has a scientific calculator built in. You don't have to remember any of the values for the trig functions for various angles. After a while, the ones you use the most will become committed to memory.Reading your conversations, a couple things. I don't have any CAD software, i don't have a slide ruler (and I picture a slide whistle...) You guys seems to know when you need to do some TRIG equations and what that problem looks like. If anything, I'm an artist. If for instance, i needed to plot out a 8 hole pattern, it would become more of a drawing very symmetrical, than it would be a math problem. I
Rock_breaker on this forum is helping a lot, but this is a large amount of need here. I don't want to crush him with all my lack of knowledge..
Im running through this online portal RJ gave me, but I'm not sure i will know when they are needed to be used when fabricating.
