- Jun 23, 2011
- 786
Asd posted here: http://www.hobby-machinist.com/show...r-man-s-Straight-Edge-for-a-scraping-standard I had an issue with my Boyar Schultz 2A618 Surface Grinder that required scraping. Long story short, I completed the scraping and reground the chuck. Got +0.0000/-0.0005 across 18 inches. Good enough for me. Probably not what could have been achieved by someone seasoned in scraping, but I'm content... It was out 0.003!!!
So, I figured I'd make something... The grinder came with several wheels and I had a bunch of W1 on hand. Hmmmm. Could that 45 degree pointed wheel be used for something? Yes! To grind the "rod grooves" for a sine bar (I machined out the majority of the material first). I'd heard that a sine bar is an "exam" for an apprentice toolmaker.
All in all, it took about 3 hours to make (things wen't way too smoothly).
Here it is all done. Almost...
As you can see I didn't go crazy with the grinding on the bottom. Just enough to be flat. The wheel really needed dressing, and I traversed and fed quickly. For the top, I used a carefully dressed wheel, plenty of Crisco for lube and followed it up with about 2 minutes of lapping on 400 grit.
I'm bringing it to work tomorrow to check the calibration, and to use a round wire brush to clean out the oxidation from heat treating the hollow rods. I was too lazy to bring down the gun cleaning kit. I'm sure I'd find a suitable brush in there...
John
John
