- May 7, 2023
- 1,505
Why would it do that while it is clearly in use?If there were nothing in the code keeping the tablet awake, it could go dark while you're in the middle of a cut and creeping up on a specific measurement. Worst case it could cause you to ruin a part, but it would at least be annoying. Certainly having it as an option would be ok, but by nature, there's going to be power available where it's being used, so I just keep the tablet plugged in my little stand on the mill table. Sometimes I unplug it if I want to move it, but it mostly stays powered all the time. Yes, this isn't necessarily great for the battery depending on the hardware.
I do t see this happening at all given it won’t shut down playing a game (as mentioned) or surfing the internet(also mentioned).
Almost all of the DRO,s I’ve used, and I’ve used a lot, have carried position when the head is powered down and the table is moved.
Unless this is not a feature here(I believe it is, but if not it should be) this should be a non issue.
As to leaving it plugged in all the time, that’s not workable in all situations. I use my tablet for several machines and cord issues arise on one machine.
I DO NOT want a dangling cord or any type of non secured cord anywhere near a lathe chuck.
This is why read head leads are screwed into the head unit.
