How would you do that with a 6" grinder? Freehand it?I would regrind a woodruff keyseat cutter to do the job
You wouldn't. At least not without some resuscitation from Harold Hall. Tried any other supply houses or ebay?How would you do that with a 6" grinder? Freehand it?
Tks
It could be done on a lathe with a toolpost grinderYou wouldn't. At least not without some resuscitation from Harold Hall. Tried any other supply houses or ebay?
The pocket has to be an arc, a 1/2" cutter would make an oblong. The undersize cutter would be a bit tricky with a rotary table, but be doable.I am a little confused at what you are trying to do. Are you trying to cut a 1/8 high slot that is 9/16 wide? If so why can't you use a 1/2 by 1/8 cutter? Why does the cutter have to be 9/16?
