Found a set of NIB TalonGrip vise jaw strips for 6" jaws on eBay, and made a pair of jaws to mount them in. Already had a couple bars of 4140 that were in the ballpark size wise. Being only around 30HRC, they're going to get scratched and dinged up, but until I get a heat treat oven, so be it.
![IMG_1376.jpg IMG_1376.jpg](https://www.hobby-machinist.com/data/attachments/414/414383-b580811ab4ea8615a15bff8cf0061a3a.jpg)
After squaring them up on the mill, and then grinding them together, they wound up .9975"x1.7850"x6.00". The factory jaws from MiteeBite are 1.00"x1.740"x6.00", I believe. Close enough. Made the counterbored holes for the 1/2"-13 SHCS.
![IMG_1379.jpg IMG_1379.jpg](https://www.hobby-machinist.com/data/attachments/414/414384-586d9f2ccc918006f4c52a82c182a403.jpg)
Lastly, the groove was cut to accept the serrated jaw strips. It's .188" deep and leaves a .125" ledge in front of the serrations. The width called for .500" +.001"-.003". I started at .005" and then gradually opened it up until the strips just started in the slot, and stoned them until they just fit. Drilled and tapped for the 10-32 mounting screws, and then broke the edges with a .010" chamfer. Look forward to giving them a try with aluminum and mild steel.
![IMG_1392.JPG IMG_1392.JPG](https://www.hobby-machinist.com/data/attachments/414/414385-554b1f41be660366257f66a4527b1ba2.jpg)
