- Oct 16, 2019
- 6,632
I do need to make the clamp thing to so there's thatNot only are they hard to find, when you do, they are expensive. That was a great find at a great price. Good for you!
Shuts, that is the easy part!I do need to make the clamp thing to so there's that
Don't forget to add the Black-Oxide 3/8-24 steel rod & Black-Oxide Steel Round Coupling Nut, 3/8"-24 to go with the thrust bearing for that dial extension. And either a taper or roll pin. Just saying . . .Nope. What I need is a way to hide the purchase from my wife... I mean, the CFO. Everything is in the cart... along with a few other things I have been meaning to buy... The other things have been there for over a month now.
Maybe next month I will build the courage to place the order...
Ha! Good guess. But that is just to add to the existing setup on the Logan 820 for a smoother turn of the existing dial.Don't forget to add the Black-Oxide 3/8-24 steel rod & Black-Oxide Steel Round Coupling Nut, 3/8"-24 to go with the thrust bearing for that dial extension. And either a taper or roll pin. Just saying . . .
FWIW my partner and I have a 17 year standing agreement. I only comment on purses and shoes regarding how nice they complement her, and she doesn't ask what goes into the shop.
Ron
I just goto McMaster-Carr site for tap drill.
LOL Sir, I knew exactly what it was for. Just joking about the dial extension option.Ha! Good guess. But that is just to add to the existing setup on the Logan 820 for a smoother turn of the existing dial.
