Update: In no particular order...
Manual mill...
1. Belt drive kits are still on back order.
2. 3hp VFD motor confirmed at 3,600 rpm, the shaft size is some custom metric size from the factory so retrofitting a Baldor, Leeson, Marathon may require turning the motor shaft. On the other hand if converting to belt drive you just machine the pulley to fit.
3. I did look around for inverter duty alternative motors, not cheap about $500 and up and nothing with the wide base mounting frame of the China motor.
4. They insure the mill for shipping with an outside company (not the freight company) and CO will deal with any insurance matters, if they can just send a replacement part they will, if the mill is half destroyed they will ship out a new mill.
5. The VFD is a Danfoss 3hp Micro drive, I checked pricing looks to be $380 to $420 for that unit. Of the $850 they charge for the VFD upgrade which includes installation, control pot, etc. that only leaves $450 to put towards another motor plus having the shaft turned down, machining an adaptor plate, bah I just decided to go with the China motor CO provides. If I upgrade to a better quality motor later I'm only out a few hundred. Also I have yet to find a better quality inverter duty motor that was 3,600 rpm like the China motor, they were all 1,800.
CNC Kit...
1. The newly designed kit includes servo motors that are pretty cool, but are not yet IP rated. CO thinks they are good to go for flood coolant but I pointed out the electrical connection which clearly is not, bottom line I would need to confirm this with the servo manufacturer.
2. All three ball screws are 20mm and rated P3.
3. The Y axis servo is now mounted on the back of the base vs the front. They machine the back of the base flat at the factory in prep for the servo so if you purchase the kit and install yourself is bolt on, you do have the drill/tap the holes.
4. CO assures me backlash is zero, if you machine a circle you won't see issues at the quadrant changes in axis direction it should be a smooth circle.
