    Dismiss Notice
Thrust Washer Material?
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by boostin53, Jan 4, 2017.
  1. boostin53
    boostin53 United States Active Member Active Member
    205
    43
    City:
    Arlington
    State:
    Texas
    -Return to Top-
    Hey guys, I need help....again! I'm in the process of finishing up my boring head ball turner. My boring head came in the other day with an MT3 shank. I made a new shank with a 3/4" diameter. I'm wanting to add a thrust washer at each end of the shank at the boring bar holder. I currently don't have bronze, any type of plastic suitable or anything.
    What I do have is aluminum and possibly brass. Would the brass work? I know very little of thrust washers. Could I find something else to work at the local hardware store?
  2. ndnchf
    ndnchf United States Active Member Active Member
    321
    63
    City:
    Fredericksburg
    State:
    Virginia
    -Return to Top-
    My local Tru-Value hardware has a hardware section with a zillion plastic boxes full of various hardware. They have one full of hardened thrust washers. Maybe you have a similar store nearby that can provide what you need.
    boostin53 and FOMOGO like this.
  3. chips&more
    chips&more United States Active User Active Member
    1,219
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Phenolic, Delrin, bronze, brass and maybe in that order? Steel against steel could gall. Aluminum could also gall.
    Ulma Doctor and boostin53 like this.
  4. boostin53
    205
    43
    City:
    Arlington
    State:
    Texas
    -Return to Top-
    I was only going to resort to aluminum if I had no brass. But I'm going to check a local hardware store or two and see what they have.
    I know there are places in the Dallas, TX area that stock items like this, I just don't know where. Tru-Value and ACE Hardware are seldomly visited by me, but I will stop by when I get off work. Thanks guys.
  5. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,830
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    as a suggestion, Mcmaster-Carr sells all the materials mentioned before
    i'd be partial to bronze or delrin myself, but there is nothing wrong with phenolic thrust washers :grin:
    JimDawson and chips&more like this.
  6. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,246
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    Thrust washers with ball bearings between two hardened steel flat washers are available. The ones I make have a maximum shaft diameter of .087, too small for your application.
    Ulma Doctor and British Steel like this.
  7. British Steel
    British Steel United Kingdom Active User Active Member
    377
    83
    City:
    Camberley
    -Return to Top-
    As Tom suggests, thrust ball-bearings are available, not expensive, make a big difference - I have 'em between QCTP top nut and the QCTP body, locks up much more solidly for less effort. I'll be using them when I get the necessary Circular Tuit to make a ball/radius turner!
    If you wanted to be really flash, there are roller bearing versions, more expensive but can take higher forces...
    Is the shank supported in suitable bushes radially or will you need suitable bearings there too?
    Dave H. (the other one)
  8. boostin53
    205
    43
    City:
    Arlington
    State:
    Texas
    -Return to Top-
    Well it turns out my local ACE Hardware has more than I thought! Never really spend much time in there. I picked up a handful of various sized bronze and delrin thrust washers.
    I might eventually end up making a new holder for the boring head ball turner. That way I can utilize some nice bearings I have at hand with a 3/4" ID. Plan is to bore a recess on each end of the home made holder for the bearings. That way the only thing the shank of the ball turner touches are the bearings.
    Using the thrust washers with a boring bar holder is temporary in my eyes. I just need to get it finished soon to make some decorative knobs for some drawer pulls for the wife. She keeps asking about them, which isn't bad. Because it means I get justified time in the shop!!!
    However, I got side tracked earlier and ended up starting a spur of the moment project. I mounted one of my pistol slides in the milling vise. Did some layout for a few slots at the top of the slide. Cut the first slot then came in for the night. Purely for looks, might have to tune the springs if it throws off the cycling too much. Anyways, enough of the off topic mumbo-jumbo!
    Ulma Doctor likes this.
  9. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    168
    43
    City:
    nipomo
    State:
    California
    -Return to Top-
    make sure you put a coating of grease on all surfaces bill
    boostin53 likes this.
  10. boostin53
    205
    43
    City:
    Arlington
    State:
    Texas
    -Return to Top-
    Duplicate post #2
  11. boostin53
    205
    43
    City:
    Arlington
    State:
    Texas
    -Return to Top-
    Duplicate post
Share This Page
