- Oct 13, 2014
- 8,718
Hi All,
The other day whilst trying to better organize my shop, I made a caddy to hold all, or at least some, of my pliers, wire cutters and the like, on my electronics workbench. I was inspired by a video I saw on YouTube by Adam Savage (Former host of the TV series Mythbusters), who espouses an anti-drawer philosophy and thus keeps all his most use tools at the ready on caddy/racks. While his rack design is very usable it didn't quite fit my needs.
I had been saving some short sections of PVC Pipe and figured I could use them to make a compact, circular rack that would fit on my bench. I also put a limitation that I could only use stuff I had on hand to make it, no purchased parts allowed.
First I mocked it up to get the basic clearances, etc. The 8" diameter outer ring is held to the inner piece of 4" pipe by fins made from a heat flattened, piece of pipe, glued in place. The inner bulkheads are ¾" PVC foam board, also glued and the bushings are turned from black Delrin.
The base is painted plywood with a piece of ⅝-11 threaded rod fastened to it with a flange I found in the scrap bin, all it needed was to be drilled and tapped for the rod. I covered the rod with a piece of rigid aluminum, electrical conduit and made a Delrin bushing to cover the jam-nut on top of the flange. The rod-conduit axil is capped with a circular handle made from an old hockey puck and a nut.
The rack turns nice and smooth with just the right amount of resistance so it doesn't spin too much, something I thought might be an issue if I used ball bearings.
Anyway, It was fun to build and now have ideas for more tool storage using this concept.
Thanks for looking.
Thanks for looking.
