*** This thread was split out of the sticky Serial Number thread. ***
Chuck,
Where is the ON-OFF switch mounted (in the headstock casting or in a separate box mounted on the front of the headstock)? Is the change gear cover fabricated (has square corners) or cast (has rounded corners)? Best way to answer would be with some photos, starting with a full front view of the entire lathe.
Chuck,
