- Apr 4, 2013
- Location
- Portland, OR
Hi folks,
I published the latest version of TouchDRO to the beta track. Most of the changes are "under the hood" (getting ready for the third generation adapters).
The main external change is a new function (well, two functions) in the graphical view of the Plus version:
The bottom two icons on the right will trigger Auto Zero and Auto Sub-Datum on Z down. When the quill moves down and then up by at least 10mm, TouchDRO will either zero out X and Y readouts, or add a new sub-datum to the list.
If your DRO is in 2D mode, the new sub-datum will be added if there is no other sub-datum within 25 microns in X/Y plane. In 3D sub-datum mode, Z will be set to the point where the quill moved up if there is no existing sub-datum within 25 microns.
Please let me know how the function works (if you have access to the Plus version).
Regards
Yuriy
Regards
Yuriy
