- Nov 20, 2018
- 775
I had the same dilemma, how much do i need to get by? My solution after much study and going back and forth was to purchase a PM 30MV. I was liking the 728 which is similar size but the 30 was 240V and physically heavier and also used the R8 tooling. I didn't want to run a 240V circuit, but in retrospect I am glad I did in the end.
I already had an Atlas/Craftsman 12" lathe in house that was the source of a similar thought as to how much i needed or could justify spending. I finally bought the mill thinking it would be handy to have, but no particular purpose on mind.
Now I wonder how I got along without either. I like the lathe even though some call it very light duty. If you take your time and learn to use it properly it works well, at least for my purposes. The mill is very similar, light duty, but very useable if you take your time.
If I were you I would buy a PM mill and sell your drill press if you need to for room. You can always use the mill for a drill press, a really accurate and repeatable drill press to boot. You may outgrow, or desire more power later, or maybe not. I am pretty happy with my setup and I doubt I will upsize anytime soon. I would have to get a really good deal on a large machine to even consider the hassle of changing.
