Two Logan questions, counter shaft and back gear.
Herk,
Do you know how old your lathe is? Or the serial number? I have not looked yet but don’t remember seeing bushings either.
Congrats on getting the countershaft sorted.
Did you ever get the back gear adjusted properly?
Haven’t tried yet. Hope to get to that soon. Seems like life and projects always put me behind. Doesn’t help that I am so slow at most projects. Lol.
Adjusting the back gears may take a few tries to get it right, but just keep at it. The suggestion to slot the shaft is a good one,
but you have to take it apart to cut the slot. I just used a screwdriver angled down through the headstock to roll the gears and
it worked fine.
Before you start, make sure the latch located under the back gear. engagement shaft is working properly.
Top Bottom
