- Feb 23, 2013
- 152
Hi Guys,
In dismantling my SB lathe , I was taking a part the apron. The upper rack pinion gear and shaft
had a taper pin in it. I hit it from the wrong direction, large end and (you got it!) it jammed in BUT GOOD.
I was finally able to separate the shaft from the rack pinion gear but the shaft has the taper pin lodged in it.
I tried drilling it out heating it to no avail. Grizzly had the shaft which I ordered, the upper rack pinion gear
has now an enlarged hole in the hub where the taper pin goes in so Does anyone have one?
Upper rack pinion gear (part #AS76R1) this part # is from the SB parts list catalogue CE3458.
Also where would I find a good source for taper pins?
Thanks..........razinman
