- Jan 29, 2017
- Location
- Tatachilla 5171, Adelaide, Australia
Understood, it messes with automotive coatings also
Removing the rust with this was a breeze... the stubborn sections required using a scotch-brite pad... but all came out... A good coat of way oil and ready to be used...
Most of the time, that is what I use... The rust on this chuck was stubborn... The amount of effort that I needed to remove it once I put a little bit of this spray, was just amazing... It is acid after all... need to remind myself to use gloves next time.WD40 also works well to clean up rust.
I guess I had it comingmaybe add a flame thrower, just to be sure..
