- Feb 1, 2015
- 9,690
EMC normally means electromagnetic compatibility and refers to the ability of the device to withstand outside electromagnetic interference without compromising the operation of the device.
EMI means electromagnetic interference and refers to suppression of electromagnetic interference generated by the device to avoid issues with other devices.
If the VFD manual is accurate, their EMC filter is concerned with preventing outside signal from interfering with the operation of the VFD and not with the VFD interfering with other devices.
Interference issues are usually best dealt with at the source of the interference. In the case of a VFD, one possible solution might be adding an EMI filter to the power cord. You may also have high frequency signals running on the 3 phase lines to the motor. The line would act as an antenna. radiating the high frequency to the surrounding space which is then picked up by the DRO. The simplest solution might be installing snap-on ferrite chokes on the line cord and the output cord. Low pass filters on the line and output leads is a more aggressive solution. Having a good ground to the VFD is a good start. You may have to install additional filtering on the on the DRO as well.
