- Jul 5, 2014
- 2,776
I've finally got the 55 running pretty well with the sniper fuel injection. Was a long haul but the data logs seem to be very close, or at least I'm told they are. Look like gibberi8sh to me, but thankfully I hooked up with a guy that is good with tuning. He hyas a sniper1 and he removed the troublesome fuel pressure regulator in the throttle body and replaced it with an external regulator, but when he put the fpr cover back on it cracked. I was able to design and cnc one out for him and have put them on ebay. I sold 8 of them in one day.
(shameless self promotion) https://www.ebay.com/itm/225795837340
Anyway the 55 is running pretty good and every once in awhile it belches out smoke, mostly from the right bank. From what I can tell it does this after a sustained run at the same throttle position and after letting off the throttle, both high vacuum situations. I'm thinking either dried up valve stem seals or bad guides, or both. It will cost me around $600 to have the heads rebuilt. Unfortunately the $200 valve jobs are gone forever.
Vortec heads are supposed to add 40 hp and I already have the vortec style intake and it also has a set of self guided comp cams 1.6 rockers so it's easy to go to the vortecs. I can get a set of stock gm ones for about $700, and then add $120, then tax about $950 total to have them modded for more valve lift. Stock one are good for .450 and the info I have on the cam is it's .450 lift, then add the 1.6 rockers which I believe would work out to .480 lift total.
There are these.
https://www.ebay.com/itm/3739958327...lWwoeBm7MTJ3BQI6IE60STyQ==|tkp:Bk9SR5yk8pbgYg
They are $829 plus $68 shipping. And since they are in Tennessee if I deal with them direct there won't be any tax. So cheaper than the iron vortecs. And I can use a regular intake manifold and perimeter bolt valve covers. I've got a nice performer intake I'd like to use and get some nicer valve covers
Has anyone here used the aluminum vortecs and bought from skip white?
There are these.
