babar, Looks like you have a different Rong Fu than the rest of us have. With the four pulleys , yes you will need three belts. Appears the motor pulley is just two steps. The usual three four step pulley setup gives 12 speeds. With that extra pulley you should have more but I would have to draw it out and do some figuring to see how many. When I got my mill it didn't have a motor so no motor pulley. I happened to have a 3 step pulley that would fit the new motor shaft so used it. I also happened to have a hand held digital tach. It has a little cone on the end of the shaft and I put a 3/8" collet in spindle and could hold the tach to that and get a reading. I moved the belts around and recorded the speeds. With the three step pulley I can loosen the
set screws and slide it up or down to give a couple more speeds.
View attachment 70008If I wanted to keep a shorter belt handy, I could get another two or three speeds but don't see the use of it. I then made up this chart, sealed it in plastic, and taped it to side of mill. Hope this helps.
