- Jun 7, 2013
- 10,245
So far as the threads binding on the parallel clamps, the clamp bodies were obviously tapped, and I suspect that the screws were threaded with a die that did not cut an accurate pitch, not matching the pitch cut by the tap, if the thread is cut for a close fit in the tapped hole, the pitch inconsistency causes the binding. Pitch irregularities in dies are not uncommon. Another possible cause could be that the thread was cut to a pitch different than the tap, or vice versa. Try a good sharp tap, matching the thread of the screws in the holes and see if any significant material is removed.
The second item is obviously the staff for a surface gage, having the ball end and scriber on the opposite end, what the other part is, I do not know for sure, have never seen this part in old catalogs, but it may have been to mount a dial indicator on the surface gage, it does not look to be home made.
