- Feb 2, 2013
- 3,646
i'll take a stab at it....
from your 2 pole disconnect,
install one hot wire(L1) from the discon to the drum switch terminal 2
run a wire from switch 2 to motor terminal 4
disconnect blue wire at motor terminal 2, splice wire, carry splice to switch terminal 3
run a jumper wire from motor terminal 2 to switch terminal 4
run 1 hot wire(L2) from discon to switch terminal6
run wire from switch terminal 6 to motor terminal 1.
if this scenario is reversed for desired forward rotation , simply reverse black and red wires at the drum switch- terminals 1 and 4 respectively
