X-Y Table Nut Oiler
RandyM
Mr. Deliberate
Apr 12, 2011
3,488
Finally got tired of not being able to oil the x-y nuts properly. So here is my rendition of the modification to my Bridgeport. I am really happy with how it all turned out. But I tell ya, there is not a lot of room under the table to run the lines.
Oh yeah, I know there are kits on the market for these, I just didn't like the idea of plastic tubing and the suggested engineering.
Mill X-Y Nuts Oiler 01.JPGMill X-Y Nuts Oiler 02.JPGMill X-Y Nuts Oiler 03.JPGMill X-Y Nuts Oiler 04.JPGMill X-Y Nuts Oiler 05.JPGMill X-Y Nuts Oiler 06.JPGMill X-Y Nuts Oiler 07.JPGMill X-Y Nuts Oiler 08.JPGMill X-Y Nuts Oiler 09.JPGMill X-Y Nuts Oiler 10.JPG
how do you oil a zerk fitting? Just stick an oiler on the ball? Or is there a clamp on fitting and oiler ?
It is a regular zerk fitting, and a regular grease gun coupler snaps on and seals well enough. The oiler has a trigger-operated plunger that pumps oil under pressure, kind of like a grease gun.
Jeff,
All of the oil fittings on the machine are of this type. They use a hand pump oiler. Here is a link and a photo.
