- Feb 2, 2013
- 3,644
My good ol' Shenwai SW900B is showing signs of excessive slop at the dial.
excessive slop for me is right around .050"
after pondering materials to construct a new nut from, delrin was immediately apparent.
its tough and structurally sound, it's easy to get and cheaper than other materials too.
so delrin it is!!!
i procured some 1-1/4" black delrin and planed the billet to usable dimensions on my Ammco 7" shaper
here is video of the planing operation:
after planing the billet,
i cut off a slightly larger than necessary piece and reduced it to final dimensions on the shaper, using a simple round nose grind.
the OEM nut is constructed from bronze ans is very rectangular in shape, with rounded corners.
i copied the dimensions to the millimeter and transposed the centerlines of the longitudinal axis and a transverse drilling for the nut retaining bolt
i special ground a HSS bit for the corner rounding operation and went to town on the nut
after cutting the profile on one side to satisfaction, i flipped the part in the vise and reacquired zero,
then matched the radius with the cut before
after i finished the blank, i punched and drilled the blank- then tapped the left hand trapezoidal threads.
there is zero backlash between the leadscrew and the delrin nut, but the leadscrew can be turned with very little effort- YIPPEEE!!!!!
i then drilled and tapped the retainer bolt to M6, to reuse the OEM bolt.
Only after completing the nut, did i transpose the dimensions to paper.
without further adieu, my version of the LH trapezoidal thread cross slide nut!
i'll be installing soon!
stand by-
same bat station, different bat time!
so delrin it is!!!
stand by-
