- Mar 13, 2014
- 46
Dearest machinists hi!
I am trying to refurbish my little (old) italian lathe (PAV 120B) which means that I have to repair the, badly worn, cross slide lead screw and nut. The lead screw measures 12 mm OD and 2mm pitch. Pitch is measured over a lot of 10 threads (that is I count 10 threads over a distance of 20 mm) and is backed by the fact that the cross slide dial gives 2mm for a full rotation.
Well, the thing is that I have not, yet, found such a lead screw....I understand that, since it 'measures metric' then it is not an ACME, but a trapezoidal screw. 12x3 mm TR screws are available but not 12 x 2 mm....
(strangely enough I found some hand-taps for 12x2 mm trapezoidal thread...so who sells the corresponding lead screw then??)
Hope someone has an idea....
Thanks in advance,
Thanos
Thanks in advance,
Thanos
