I'm. Still slowly. Trying to figure out how my 1944 Logan 820. Works. It has quick change gearbox. . Power longitudinal power feed works. But I have yet to figure out how the power cross feed works. Some help needed. Thanks. Scruffy
Here is a picture from the Logan 820 Manual showing the carriage controls.
Power feed lever Up = longitudinal feed, Down = cross feed, Center = neutral
Note that there is a mechanical interlock that prevents the half nuts from being engaged if the power feed lever is not in the neutral position and the power feed lever from moving if the half nuts are engaged.
When using power feed (either longitudinal or cross) the friction clutch must be be tightened to actually cause movement. (Mine had a broken pin that prevented it from working correctly when I first got it, an easy fix once I figured out what it was.)
I strongly recommend getting a copy of the manual from Scott Logan well worth the $25
http://store.lathe.com/pl-06.html
