- Oct 18, 2016
- 2,872
Came across this tool on another forum and though it would be of interest.
Called Vampliers, these are designed to grasp rusted or damaged screws and remove them.
I know vice grips work for this (usually what I use), but these look potentially better since they're
designed for the purpose. Made in Japan.
While I'm at it, this tool is one that I bought a couple of years ago and have found useful:
a cable tie cutter. Notice the tip is 90 degrees to the cutting edge, which allows it to be slipped
under the cable tie without danger of clipping a wire. They're actually quite nice to use.
VAMPLIERS® 6.25″ SCREW EXTRACTION PLIERS - Vampire Tools
High-quality specialty pliers to extract stripped or stuck screws and rounded nuts or bolts. Remove stripped rusted corroded, damaged, jammed screws, bolts, nuts Made in Japan from high quality carbon steel Designed with VamPLIERS® Technology Target screws can be extracted using top jaw or side...
www.vampiretools.com
