- Dec 18, 2013
- 2,012
I finished plumbing the Accu-Lube minimum quantity lubricant system (MQL) and fired it up for a test today. This is a micro-drop type system that sends out a spritz of lubricant micro droplets its not a mist system. It also has an air powered/timed pump to deliver the lubricant in bursts.
Here's a rear shot of the mobile air cart, this provides air for the Accu-Lube, Maxi Torque-Rite power drawbar, and an air hose for blowing stuff off.
I elected not to try machining anything today due to the amount of water I saw collecting, its raining today and there's a lot of moisture in the air. I'm going to look into an air dryer, I don't want moisture running through this system or out onto the mill.
There is plenty of reach via the 18 inch long line locs. I could have located the magnet base up onto the nod area of the mill for additional reach. There's plenty of hose I had to coil up the excess and secure with a zip tie.
This is after several minutes of operation aimed at a piece of paper. It does indeed spritz out as advertised. I had it set to pump about every 2 seconds which, each time it pumps you hear a slight thump and a spritz comes out.
The Accu-Lube has several adjustments, the pump frequency is adjustable from like once a minute to a rapid fire several times a second. Downstream from the pump the volume of lubricant is also adjustable. I had it adjusted to the recommended setting for general use. The air is also adjustable so three settings total.
Lastly I'm declaring FAIL on my purchase of the Rolair compressor for this. I didn't have the air blasting and its clear the compressor will run pretty much continuously and at 95 decibels I'm just not going to listen to that volume of noise. I'm going to try the much quieter made in CHINA California Air compressor.
