- Apr 8, 2021
- 15
Last year I acquired a Dah Lih GH-2200 dual head milling machine. I have been slowly cleaning and repairing all the dirty and loose parts on this mill. One of the items was the loose lash on the Y axis travel, it was .025-.035". It has two feed nuts opposing each other for this adjustment, with the table in the center of the travel if you adjust them it takes most of the lash out but then when you travel to the ends it gets very tight. With this machine being 40 plus years old I expected to have wear in the nut so I started to disassemble and found the brass threads to be worn to a knife edge. I then ordered 2 nuts and waited for them to come in, after they arrived when I tried to screw them on the acme screw I found out that it was very tight to screw in, it would only screw in about a half a turn. At first I thought I ordered the wrong part but after checking and measuring again I found out that it was the right thread. I proceeded to check the feed screw and found that it was worn in the center, but I guess that's ware all the wear happens anyway. I was about to machine the nut to make it fit the screw but then realized that even if I did that I would still have the tight issue on the ends of travel with a worn screw. So I proceeded to machine the screw to fit the nut instead, when I set up the screw in my lathe and dialed in my cut, as expected it would only cut the thread on both ends. I machined the thread so my cutter would cut the thread on the ends of the shaft and only touch the center of the screw ware it was worn the most. In my head all the thread should be at the same dimension and should eliminate the tightness on the end of my travel. When I then installed the new nuts on the shaft they went in pretty snug with a nice fit.
My question is? Is this an acceptable repair or did I just ruin the screw?
Are the replacement nuts machined undersize to anticipate the ware?
I am new to machining and I am tryin to learn. What other way or what is the correct way to repair this?
I know I could have ordered some new acme screw and weld it to my shaft but wanted to keep cost down.
I have other machinery I still need to refurbish so this wont be the only time I will see this problem again.
