Many of the requests for "what should I buy?" are pretty general . Many times it includes the term "small stuff". This does not aid my search for advice as the information is too nebulous . So here are some very specific points:
What I have:
Unimat DB200 with all the accessories (probably going to be the funding source)
Maximat 7
1930's Craftsman 12 x 24 lathe in decent shape but not as sharp as the Maximat
What I need these machines to do right now: (I repair musical instruments for a living)
make hand tools (screwdrivers, small cutters, small scrapers)
fab parts for musical instruments (mostly brass and plastics, all the steel work is on the lathe (tool steel mandrels for dent removal, little screws and hinge rods))
basic shop needs (jigs, holders and clamps, other fixtures for metal and woodworking tools)
Coming up:
I'd like to upgrade my machining by better controlling cutting tool geometry and general precision.
This means making a better grinder rest, indicator holders, more QCTP holders for either lathe, tool height gages, etc.
I will also be getting into production for profit (hopefully) of hand tools for others in my industry. This mainly means making jigs and holders for repeatability in grinding and milling processes.
I am very tired of using the Maximat for a mill and lathe at the same time. Going back and forth between the milling and turning operations is way too time consuming and distracting. Also, the milling capabilities are much less than the turning precision of this very nice lathe.
I will definitely be getting a mill with DRO. This will make some of the repairs I do now much better and easier (for example, clarinets need very precisely placed holes, and right now I have been getting by with a fiddly sort of copying jig on the drill press that is not very precise or rigid -both the jig and the drill press -- the clarinet jig will not fit in the Maximat's work envelope)
I'm thinking of getting a Sherline 5400 mill with installed DRO. The Maximat will become a dedicated precision lathe and stay that way.
The Sherline fits my budget and space requirements. I believe it will be as precise as I can make it at my skill level. Thinking about a larger bench machine is a little problematic due to shop space requirements and the fact that my budget just maxes out at $2000.
I have no doubt the Sherline can handle anything I throw at it in plastic, aluminum, or even brass. My question is, will this machine do this -- Shape and size steel needed for jigs, fixtures, etc.? For example, can I drill through 3/8" (or even 1/4")steel plate and connect the holes to make a slot? Can I use it to make Harold Halls grinder rest out of even mild steel? Can I use it to mill dovetails for BXA tool holders for the 12" lathe? (aluminum holders for the Maximat are not a problem, I'm sure). How hard can I work this machine and still remain in its comfort zone?
Or should I sacrifice something else to move up in budget and size? (and weight -- moving and lifting a 400 pound machine would press the limits of my ability and add the expense of a stand to the package). For example, a PM mill with DRO is already almost $1000 over my budget. That does not include all the R8 tooling, larger vise, etc I'll need to get it working. I already have a lot of tooling that will work on a smaller machine.
Thanks for reading this far and thanks for any advice you have. I feel like I'm at the altar and priest just said "if anyone has any objection .... let him speak now or forever hold his peace" I think I've made my decision and this is the last chance for someone with more experience and knowledge to stand up and say "Sure, now you like that pretty little thing, but just wait two years and you'll be sorry you didn't make a different choice!"
What I have:
Maximat 7
Coming up:
