- Nov 10, 2011
- 1
Sorry, I know the topic has been raised before and yes I have read the prior threads. My question for you guys now is a bit different and not as straight forward so here goes. I want to reduce the FPM blade speed on a 14 Craftsman wood cutting band saw. To that end I first sought out and found a 30 to 1 speed reducer which is rather large, but will surely be stout enough to get the job done. Fast forward several weeks and lo and behold I acquired another speed reducer, this one is much more compact but looks to be built heavy enough to get the job done. However, I fear it will just be way way to slow at 60-1 which if my understanding is correct is about twice the reduction I will need to be at optimum FPM blade speed. So my question is am I correct that the 60-1 will just be far to slow to use and I should just stick with the 30-1 reducer?
