Anvil Cart Base
dlane
Sep 27, 2014
3,123
Made a base with retractable wheels for my Peter wright 105# anvil.
Stepping on the lifting arm lowers the wheels that lock down, notice the white welding table with the same setup behind the anvil . Shop space is limited so almost everything gets wheels
Makes moving things to a useable space mo better.
Good idea, dlane. Got any detail pictures of the locking mechanism?
Everything in my shop is on wheels. I put wheels on one end of my welding table and a retractable handle on the other so I can roll it like a wheelbarrow. The handle doubles as an extension support.
Thanks Franco
Gravity , I'll get a better pic tomorrow
Have you found that the expanded metal fence helps to keep the other machines from taking over the shop? :)
Integration of wheels is a great idea!
Please consider a detailed pic or drawing of the mechanism.
Daryl
MN
I meant how the wheel locks down so you can roll it, dlane.
Very simple but effective, step on the lifting arm which is hinged at the other end ,
the base raises off the ground and the locking bar drops down vertical ,this pic is it locked down
Notice the legs off the floor
I made it so it lifts about a 1-1/2" when the lock arm is down. I have a detachable handle to roll it around where I want it , then step on the lifting arm again and push the lock arm forward with foot to
Release/ and lower base, like so
This is how I did the welding table several years ago, excuse the mess
A little more material but worthwhile if mobility is needed.
Daryl , it'll take more than the expanded metal to stop that, too late.
