anvil
12bolts
Global Moderator
Apr 23, 2011
2,476
I have a good solid timber block that I use for mainly wadpunching and bashing copper, but as I am working steel more it is not solid enough, nor durable enough when working hot....
...and up here in north Queensland 2nd hand anvils seem to be difficult to be had, so I decided to make one from some old 2" plate and flat bar I found.
1st I cut the 2" x 5" bar into 5 equal lengths and the anvil top from the 2" plate.
Then I set each piece of the bar perpendicular to the table and milled one end flat and square.
I tacked a piece to the bottom of the anvil top to thicken the horn....Yes I know my oxy cutting leaves a bit to be desired....I did think about photoshopping that one :D After roughing it out with the torch I welded and ground it to shape several times.
Drilling one of the base legs for the hardy hole and pritchel hole threw up some obstacles, and a few novel clamping arrangements were called for
I drilled a 3/4 pritchel hole and a 31/32 hardy hole that I filed out to 1" square.
After welding the 1st base leg, (closest to the horn) on 2 sides and across the rear, I added the 2nd leg, welded the same and so on. Then after multiple runs to stitch the legs vertically to each other and across the bottom of the feet I set the anvil pependicular and milled the bottom of the feet flat, before flipping it over and milling the anvil work surface flat.
A lick of paint and all that was required was a solid stand.
2 x 8 hardwood, dressed, glued and bolted together and it was all ready to run.
All up I reckon it cost me a packet of rods, some paint, and a bit of electricty. I'm guessing it comes in at about 250 lbs.
It does'nt have any ring, just more of a dull thunk, when you hit it, but in use it does have great rebound. It is so much easier moving metal now.
Cheers Phil
I think that looks great. Don't sweat it about your oxy/acet cutting. A piece that thick is a bear to cut for anyone, you did a fine job.
-Ron
author=Paddy OFernichur link=topic=1859.msg11947#msg11947 date=1303775791
....when you are prepared to upgrade on a face mill, I can help.....
Hi Paddy, Actually I worked that cutter pretty hard on this project. It needed a grind halfway through and again when I was finished.
I was a machinist a whiles back but have been out of the trade for a long time. Now semi retired and fullfilling my hobby instincts I have been sniffing around the auctions picking up what I can. That cutter and a box of Osborne collets and endmills came with the machine. I had never seen that type of face cutter before. Any slab milling I ever did was on a horizontal machine. What sort of cutters are available for vertical slab cutting that you allude to?
Cheers Phil
One question that I have is "How do you find 2" thick steel laying around"? All of the metal I find is all small stuff and hard as hell to machine. Nice anvil by the way.
Paul
Nice anvil! Nice project for anyone. I trust you did not try to lift that by yourself?
I know this post is a little old, but not that much.....I like your work making your own anvil. Making a square hardy hole is a challenge for sure. You did a very nice job, sure beats one of those Chinese pieces of imitation cast iron anvils that are available.....nice job SIR.....
