Hi im new to the forum and this is my first post besides my introduction. My problem is with a belt sander with a 1/4 hp capacitor start motor. I was given the sander and i was told the motor ran but seemed to run a little slower then it should. I did not test it at that time. I brought it home and tried it out but the motor keeps pulsating on and off. The whole start stop cycle only takes a few seconds but will continue if plugged in. I serched the internet but nothing described this problem. I believe that it may only be running on the start winding and it stops once the centrifugal switch cuts out and then the cycle repeats. My question is has anyone had this problem before and is it repairable or should i look for a new motor? The motor is covered in steel powder and oil and alot inside it. Possibly some was dislodged in my trunk and got in the motor should i start cleaning it out or is it a lost cause? Thanks Ed
