I found a Grizzly G9729 on marketplace. I have questions about it. Can mods be made to let it go down to 0.5mm thread pitch? Grizzly says no but I'm guessing it could be possible. Hope to not be a pest about learning how to run this machine.
Unfortunately, I'm committed to buying this machine now. I'll research modifications to get the threading ability down to what I need(0.5mm).Thread dial. Won't be able to use the thread dial, half nut yes, for metric threading
I would reconsider buying that combo machine- it's not convenient having the mill head hanging over the lathe headstock like that.
The machines that have the mill portion bolted to the rear of the bed are a much better choice- as far as 3 in 1s go
And overall it's much better to have two separate machines, even if they are small. Changing setups between lathe and mill is a true pain
We try to steer folks away from the combo machines because of their many limitations and poor resale value
I appreciate your response. I look forward to getting this machine and learning how to run it.Looking at the manual, replacing the 24t gear on the lead screw gear box input shaft with the supplied 48t gear will allow you the thread .5mm threads. There may be an issue with clearances though. (Fig 52 in the manual.)
Edit: I looked at the manual again. The 48t gear is used for position A for cutting a 1mm thread so you would need a second 48t. gear.
