If you shoot one or two cartridges all the time, like benchrest guys do, you can make a simple trimmer using an end mill. A piece of round stock (people that do their own barrels have plenty of barrel ends laying around that already has a hole in it) run the reamer in one end up to the shoulder. From the other end, bore a hole for an end ill, I used a 5/16" to the end on the case/reamed false chamber. Set screw in the side to hole the adjustment moving the endmill to the right place. You have a case trimmer that uses the case shoulder as the stop, and the endmill cuts the end of the neck with a few twists. works great for the BR guys, who keep their brass in top condition.
