- Mar 30, 2014
- 115
So I am wanting to buy a new chuck for my lathe. It has a D1-4 spindle. I currently have a direct mount 6 inch that came with the machine. Jaws are a little bell mouthed, but otherwise works fine. It does not have reverseable jaws (but has the 2nd set of jaws for gripping external stuff) its just a pain swapping jaws. Also the size has been a limiting factor on several things I have wanted or was trying to machine. I am wanting to upgrade to a 8 inch 3 jaw chuck. I am still keeping what I machine well within the limatations of my machine, I just would like a little more room to work with (chuck wise) and kinda like the reverseable jaws.
So shars chucks seem to be generally well spoken of here and seem like a reasonable "bang for the buck" since my budget is limited. I was wondering is there are any advantages or disadvantages to buying a plain back chuck and a seperate backplate, or buying the direct mount model? Pricewise, there is only a few dollars difference.
Specificly, buying these:
http://www.shars.com/products/view/962/8quot_3_jaw_Self_Centering_Scroll_Lathe_Chucks_2_Piece_Jaws
http://www.shars.com/products/view/20189/8quot_D14_Fully_Machined_Lathe_Chuck_Adapter_Plate
Or buying this:
http://www.shars.com/products/view/...entering_Scroll_Lathe_Chucks_D14_2_Piece_Jaws
If I have seen some threads on here correctly, is it my understanding you can, or have to, take a backplate, mount it to your spindle and "true" it up? If so, I suppose I can see a slight advantage to the seperate chuck and backplate. Being able to true it up before mounting the chuck I could see as being a potiential of more accuracy. So far that is the only advantage I see for seperate chuck/backplate Vs the direct mount.
I know on my current chuck, if I take it off (to run my 4 jaw) and then go to put it back on, I have to get it back in the exact same set of holes (I have chuck and spindle marked for this reason) otherwise it has more runout. I suppose thats one disadvantage to a direct mount. You have only 3 chances to get a good/acceptable ammount of runout. If none are good, could it even be adjusted?
Thanks for any input or advise you can give me.
Or buying this:
