Gorgeous! Very fine workmanship, which is necessary for clock making, which is what I only assume it is somehow used for.
Do you have any photos of how it is used?
It is used to adjust the distance between wheel and pinion for a good mesh. Than the pointed scribes underneath are used to mark the position for the bearings on the clock plates.
As soon as I have a pair of wheel and pinion done I will post picture of the tool in use.
