- Aug 22, 2012
- 4,130
I'm trying to make a clutch/friction drive for the slo-mo control on my telescope.
I've fabricated a proof of concept to see if it would work and it does with a very smooth motion.
but! (always one of these)
If I move the telescope by hand it overcomes the friction as it should but the shaft turns and unscrews the nut controlling the friction pressure.
Any ideas how I can prevent this from occurring considering that it will be a knurled large wheel not a nut so the tension can be varied with it.
One thought I've had is to use a deep groove bearing where the outer race is set in the arm and the inner race is a tight fit to the bolt.
