- Jul 11, 2014
- 496
I have some steel pieces color coded with a violet/purple end. I know this designates the type of steel. (I've forgotten more than I ever knew about steel types) They're both hot rolled (I believe) one 3/4" and one 2 1/4". I had thought they were 1018 or 12L14 but they don't cut the same as the other 1018 and 12L14 I have. (I had purchased a 'Lot' of 12L14 & 1018 off E-bay).
The surface cut seems to pull when facing or turning, as if the tool is dragging the metal up the surface. I was running at 300-350 rpm. Slower than I usually cut the steel I have. The chip was turning blue with .008 & .014 feed. I should have taken a photo but didn't. I thought it might be the HSS bit I was using and changed to carbide. I checked to make sure the tool was on center. Nothing helped get a better surface. I've not had this problem with the other steel I have, I thought it was all the same. I think this was a different grade as it seemed tougher.
I finished it off with a Heller file and then a Bastard file then 100/220/320 grit emery. So the surface is acceptable now but I just turned another piece and got a better surface finish with just a carbide tool bit and some 220 grit emery.
Any idea what steel this could be?
