A similar tip for turning small diameter < 3/16 or so stock with a center is to turn a point on it @ 60 degrees, and take a tap with a center hole in the shank end of it. Chuck it in your tailstock chuck and run it against the stock with a bit of lube. Of course, small diameter stock will flex, so very little pressure should be used. And of course, length must be allowed to face off the point after you're done.
